Group drawing elements
Is it possible to group elements of a drawing for easier selection later?
I have a rectangle with rounded corners that I'm going to offset. Later, I may want to select that same rectangle and do something with it. When there's only the rectangle in the sketch I can drag-select the whole thing, but when there are other things in the sketch, that is no longer possible and I'm clicking on all the tiny little elements manually.
What's the workaround?
