Multiple small flanges instead of one big one
Jason_Holt
Posts: 4 PRO
It's easy to make a flange, and easy to make a flange narrower using "modify face". But what if I want to turn a long flange into multiple lit, like this:
https://cad.onshape.com/documents/a6bdb34235bb22181c3cdc1a/w/5a554c9c2ff1d2ad9a845444/e/82ee62d57befbaee0630a233
Only solution I can find is to subtract extrude after finalizing the model, but then the cutout doesn't get made from the flattened sheet metal part.
Digging deeper, after using modify face to shorten the first flange, I can make a second flange that goes the opposite direction (blue part):
https://cad.onshape.com/documents/35d308ecd1c5c38187f0df11/w/d036e23a77b982951307a735/e/65d8a0ce1659da40b286d23f
But if I try to make them both go the same direction it fails (gray part).
Try using extrude+cut and make sure the extrude goes through all the bend as well5
Digging deeper, looks like onshape is confused about where the second flange goes. That looks like a legit bug to me. (Look at the square in the lower left corner of the unfolded part -- that corresponds to the lower flange)
Thanks, that does seem to work. It was tricky getting the cut to extend through the entire bend, but oh, I see, I can create sketches on the flat part as well.0
@Jason_Holt
"Up to vertex" end condition of extrude is useful for doing cuts that need to cut through the entire bend, but none of the base plate.Jake Rosenfeld - Modeling Team1 -
You can also create the extrude cut in the Flat pattern without set the extrude depth
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2
