Project from other plane
Jason_HoltJason_Holt Member Posts: 4 PRO
I've been in this situation several times:
I draw a sketch on plane A.  Then I make plane B that's tilted from plane A.  I draw a sketch on plane B and I want it centered directly above (normal) to plane A.  If I "use" the sketch from plane A, it'll project it along the normal for plane B, not plane A.  The only way I can find to project from plane A is to extrude it and then intersect.  Could we have a "project from source plane" feature instead?
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    edited December 2018
    What's the desired end goal you are trying to accomplish? Do you have any screenshots of what you are aiming to do? Maybe also sharing a document link so we can take a look as well. Whenever I am trying to do something like create a bracket with an offset or angle to it I will do an extrude intersect as my final action to get the result I'm looking for.
    Twitter: @bradleysauln
