Top ten improvement request (updated)
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
in General
I have updated the list that I made in June with the last updates in Onshape (I have indexed the implemented ones)
1 - Exploded Views
1' - Feature Tree Folders (Implemented on December 10, 2018 v1.89)
2 - Coloring faces
3 - Global variables
3' - Part Replacement in Assembly (Implemented on November 12, 2018 v1.88)
3'' - Make Part Transparent in Assembly (Partially implemented)
4 - 3D sketching / curves
5 - Assembly configurations
5' - Sheet Metal Features (Partially implemented)
5'' - User defined materials, or adding a weight for a part (Implemented on December 07, 2017 v1.72)
6 - Create and edit variables from within a sketch
7 - Center of Mass Symbol
8 - Mirror feature for assembly workflow
9 - Assembly interference detection
10 - External cosmetic thread
10' - Configurations (Implemented on January 8 v1.73)
And this is my own top ten list updated:
You can take a look to this post discussion: "Part numbers and duplicated parts in Part Studios"
1 - Exploded Views
2 - Coloring faces
- Handle identical parts in Part Studios and BOMs (Group by name or part number)
- 3D Sketch
- Mirror in Assemblies
- No-CAD users who can edit properties
- Notes in Part Studios and Assemblies (Weld, surface finish, tolerances,...)
- More options to create teams & share (hide other members in teams and Share a few tabs of a document)
- Drawing properties templates (or in the settings) & change individual properties of an element
- Coloring faces
- Textures and cosmetics threads
- Full Parametric Sketchs in drawings
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común
1
