Fillet, Tangential Propagation
famadorian
Member Posts: 390 ✭✭✭
I'm creating a fillet on an edge, but I don't want it to propagate to the whole edge, so I turned off "propagation", but it seems it doesn't want to do it along the edge, where the edge also has been sketch filleted.
All is well if I turn on propagation, though
Any pointers?
Any pointers?
How thick is your material? (Will a smaller fillet radius value work?)
HWM-Water Ltd0 -
I tried 1mm, but also not working.owen_sparks said:How thick is your material? (Will a smaller fillet radius value work?)
Here's the document:
https://cad.onshape.com/documents/35acefae7361d2f4eef1affd/v/19648a4d3800cc3434978a7d/e/8c7f5d6b7b757b4ae5e6ba47
The only way you can do this is to remove the sketch fillet and add it after the fillet you do not want to tangent propagate. If that makes sense?Senior Director, Technical Services, EMEA0
I made a new extrude for that part of it that I didn't want a fillet for.
Thanks;)
1
