Extrusion Direction based on Collision Evaluation
Hello,
I am trying to create a routine that changes the direction of the extrusion based on a collision evaluation.
The script performs this task right after sweeping a cylindrical structure.
My goal is to extrude another cylinder (different to the original), in the opposite direction.
My initial though was to use the "evCollision()" to determine if the extrusion generated an INTERFERE clash and then change the direction by multiplying normal * -1, as shown here:
var extrude_params = {
            "entities" : qSketchRegion(id + "sketch1"),
            "direction" : evOwnerSketchPlane(context, {"entity" : qSketchRegion(id + "sketch1")}).normal * -1,
            "endBound" : BoundingType.BLIND,
            "endDepth" : 1 * millimeter,
            "operationType" : NewBodyOperationType.ADD
        opExtrude(context, id + "extrude1" + unstableIdComponent("1"), extrude_params);        // execute extrusion with default parameters
var clashes = evCollision(context, { // execute collision test
"tools" : qCreatedBy(id + "extrude1", EntityType.BODY),
"targets" : qCreatedBy(id + "bitBodySweep", EntityType.BODY)
var interfere = ClashType.INTERFERE;
if( clashes[0]['type'] == interfere ) { // if the number of clashes detected is greater than "4"
extrude_params.direction = evOwnerSketchPlane(context, {"entity" : qSketchRegion(id + "sketch1")}).normal;
opExtrude(context, id + "extrude1" + unstableIdComponent("2"), extrude_params);
println( clashes[0]['type'] );
My challenges are the following;
- Since I am not using a "try-catch" (because the collision does not raise an error), how can I avoid generating the first extrusion ("extrude 1")?
- Could I create my own "error" for "try-catch"? If so, could someone give some advice?
- I am also having issues with adding the .ADD vs .NEW parameter on the extrusion. Hence, the current script only generates new parts.
I always find myself overthinking the solution, so I am very open to suggestions!!!
The original script is here
  • kevin_o_toole_1
    If you want to create geometry but be certain its changes don't affect the Part Studio, the best pattern is to begin it with a startFeature() call and end it with an abortFeature() call. Try-catch is not needed for this pattern to work (though it's common to surround the whole thing in a try {} anyway, to prevent the entire feature from failing if your heuristic fails).
    For some good examples, see the use of abortFeature() in booleanHeuristics.fs and hole.fs.
