Draft hole in Sheet Metal
dan_schwartzdan_schwartz Member Posts: 16 ✭✭
Hello
I try to make hole with draft, or holes with chamfer for flat screw.
It's impossible.
  • lanalana Onshape Employees Posts: 757 image
    Currently such holes are not supported as sheet metal operations. You can use Finish sheet metal feature, after that chamfer or draft would work, but will not be reflected in the flat pattern.
