How would I create a "diagonal cylinder" or a "tilted cylinder"?!?!? I cant do it!!!
yeetyeet Member Posts: 3 EDU
Pls help I need this for a school project *_* - I need to create this in OnShape - can anyone help???
Image result for tilted cylinder
(P.S. this is basically the only image I could find!)
    edited January 2019
    If it's a school project then we probably shouldn't do much more than give hints. If it were me though I'd be using three sketches, an additional plane and a loft though 🤔
    HWM-Water Ltd
    Did you get it working?
    Cheers, Owen S.
    HWM-Water Ltd
    use a sketch with a circle cross section and another sketch with a slanted line, then just look at the sweep command
    Yeah, that's much better than mine!
    HWM-Water Ltd
  • yeetyeet Member Posts: 3 EDU
    Thanks for all the help! Yes, it is a school project but we are allowed to research different ways to do things.
