Is it possible to keep the original orientation of a patterned feature during a Circular Pattern?
StephenG
Member Posts: 385 ✭✭✭
I have a linear slot feature that I want to pattern around a hole and maintain the orientation of patterned feature.
Here is what OS allows me to do....
But what this is what I desire...
I do not see an option within Circular Pattern feature control panel to effect it.
it's not possible with circular pattern but, you can use curve pattern by circle
5
5 -
Yep, the Curve Pattern feature w/Keep Orientation option did the trick.
Now if I could only suppress individual occurrences of the pattern I would be one happy clam.
Thanks!0 -
You can also use the Point Pattern featurescript. It would let you place points wherever you want. And if you want to skip an instance, just don't place a point there.Now if I could only suppress individual occurrences of the pattern I would be one happy clam.
Thanks!
Point Pattern FS1 -
The "Point Pattern" Feature Script I found (Cody Armstrong's) appears to be a work-in-progress; it is only capable of patterning part entities. It should be capable of patterning feature, surface, plane, and mate connector entities.
Yes, I could have used it by...- Creating the slot feature as a cutting tool part volume
- Creating a circular pattern of 8 points
- Use "Point Pattern" selecting just the desired points (locations)
- Use Boolean "Subtract" to create the slot features in the target part
Thanks for making me aware of this Feature Script.0 -
You can use delete face or delete part to get rid of the instances you don't want1
Yes, using "Delete faces" is also a good suggestion to accomplish the result. I like this approach because it makes it easier to interpret/see design intent in the Feature list. I can rename the "Delete face N" feature name to "Remove unwanted pattern instances".
(Use "Create selection" w/"Tangent Connected" to speed the face section process for the slots to be removed.)0
