<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Extrude, Keep Edges
famadorian
Member Posts: 390 ✭✭✭
If I extrude something like this, the edges disappear.
What I mean is that I've specifically made cuts here that I want the extrude to keep.
If that's not possible, then I'm not sure which workflow I should be using, cause this is a cabinet and when I attach the door to this cabinet in the assembly, I don't have the edge that I want to attach it to.
https://cad.onshape.com/documents/a3610a44fdd7c3eb8128d329/v/ef5ec9cd30c496a8b6f3635c/e/361a1676f80cbe423bcba51c
@famadorian
You will have to do this as two extrude features. Sketch regions that are touching in an extrude feature will automatically merge with each other, no matter what boolean option is set. Do the extrusion of the outer box first, and then do a second extrusion of the shelf, making sure to set "New"Jake Rosenfeld - Modeling Team5
If you’re using “add” then any intersections will merge with the rest of the model. If you use “new” it will keep the edge. I think that is what you are asking?Senior Director, Technical Services, EMEA1
Ok, I tried using "New", but it complains that "No merge scope selected", even though I checked "Merge with all"
You image says “add”?Senior Director, Technical Services, EMEA0
Right, but I was using "new"; sorry, was confused.
However, when I use "new", the edges disappear.
Here's the result of using "new"; the edges I want disappears from the final extruded result
I want to somehow get this edge, which was in the sketch
I need this edge to put the door on.
I can ofcourse make a whole new plane and add some geometry there, but if there is a way to get this edge, it would save me that step.
@famadorian
You will have to do this as two extrude features. Sketch regions that are touching in an extrude feature will automatically merge with each other, no matter what boolean option is set. Do the extrusion of the outer box first, and then do a second extrusion of the shelf, making sure to set "New"Jake Rosenfeld - Modeling Team5 -
That or after the extrude, split the front face with the planar faces created by the extrude.
https://cad.onshape.com/help/Content/splitpart.htm
Jake Rosenfeld - Modeling Team0 -
Thanks;)
Jake_Rosenfeld said:That or after the extrude, split the front face with the planar faces created by the extrude.
https://cad.onshape.com/help/Content/splitpart.htmJust as another alternative, there is a custom extrude feature that does that. Now who wrote it? I think it was a Jake Someoneorother, hang on a minute I'm sure it will come back to me
O.S.Business Systems and Configuration Controller
HWM-Water Ltd1 -
@owen_sparks
( https://cad.onshape.com/documents/cf2ebd36a36695408b9650a9/w/8e89a7bc10431e16fe2fceb7/e/b34a987c9a30ef7498b53f66 )Jake Rosenfeld - Modeling Team0 -
That's the one, clever chap that Mr. J. Someoneorother
HWM-Water Ltd1
