Feature request: Conditional or Suppression on Folders
Would be nice to either use a conditional variable on a whole folder (i.e block) or to simply be able to right-click on the folder and do a suppress (suppressing all "actions" in that folder).
Example. If you have a variable that defines the size of an object you might or might not fit in a specific feature.
I'm making a electronics casing (round) and if I reduce the diameter below 50mm some features (like USB port openings) will not fit. I.e I want them gone.
1
HWM-Water Ltd
