When is it valid to configure multiple instances at once when creating an assembly configuration?
StephenG
Member Posts: 384 ✭✭✭
I couldn't help but notice the prompt (see red box) for configuring an assembly feature implies that multiple instances and/or mates can be selected at once for configuration.
Given the different type and number of parameters that might exist for each individual instance I would not think this would be supported.
So why do I want to configure multiple selections?
Essentially, I want to propagate the "Configurations" table with multiple selections in one fell swoop to control feature suppression. When multiple assy features/instance are selected I would think that only the feature parameters common to the selection set would be added to the "Configurations" table, in many cases that would be just suppression.
I can preselect the assembly features for configuration prior to pushing the "+ Configure Assembly Features" button, get the selection prompt to proceed but the multiple section is ignored. At this point I can only select a single assembly feature at a time
Right now the process to build the Configurations table can be rather tedious. Looking for a way to speed things up.
Adding a suppression is quicker to do from RMB menu in list with 'Configure suppression' but I feel ya.. Creating assy config for fillets on/off for 10 parts needs way too many clicks..
As expected there is already IR logged for this and with enough feedback we usually see improvements in future updates.//rami1 -
I tend to usually add to the configure list by going to the feature I want to configure, then adding it to the appropriate configuration parameter.
This just gives an additional way to do the same thing. So it doesn't hurt to have it. Some may like the +Configure feature better than digging them out one by one.
So I can't say that I haven't used it. But typically I configure as I go. Rather than waiting to the end and adding a bunch of things at once. But it is nice to know I have the option
