Is there a way to get specific information of a mate from API?
C_Justin
Member Posts: 16 ✭
Is there a way to get how a mate limit two different parts from API? Like which axis the mate will constraint and how much freedom are allowed on each direction?
There is. You will have to call the assembly feature list API. For example, I made an assembly with a revolute mate limited to 45 degree rotation here: https://cad.onshape.com/documents/cca81d10f239db0db9481e6f/v/369ac699891d9659ce2d42ba/e/32fbe5d87f9b2777a37ddee9 . When you call this endpoint (just put it into your browser that is signed in to Onshape): https://cad.onshape.com/api/assemblies/d/cca81d10f239db0db9481e6f/v/369ac699891d9659ce2d42ba/e/32fbe5d87f9b2777a37ddee9/features you should get the following: (I deleted the nonessential bits for brevity)
{"features": [{Under features[0]["message"]["parameters"][2]["message"]["expression"], you'll see my z axis offset of "-0.25 in", and under features[0]["message"]["parameters"][5]["message"]["expression"], you'll see my z axis axial limit of "45 deg". Note that these parameter lists don't have a guaranteed order, so don't hardcode the location (here, 2 or 5). Instead, you should filter based on the type, and subsequently the parameterId. For the offset, the type is "BTMParameterQuantity" and the parameterId is "mateOffsetDistanceZ". For the limit, type is "BTMParameterNullableQuantity" with a parameterId of "limitAxialZMax". Hope that makes sense!
"type": 64,
"typeName": "BTMMate",
"message": {
"mateConnectors": [],
"version": 2,
"featureType": "mate",
"featureId": "MHRrbsJgjRWu3+Iaf",
"name": "Revolute 1",
"parameters": [
"type": 145,
"typeName": "BTMParameterEnum",
"message": {
"enumName": "Mate type",
"value": "REVOLUTE",
"namespace": "",
"parameterId": "mateType",
"hasUserCode": false,
"nodeId": "pfmse+zfxKRK6dpx"
"type": 144,
"typeName": "BTMParameterBoolean",
"message": {
"value": true,
"parameterId": "mateOffsetEnabled",
"nodeId": "hlflbMRsVZ/Es5eF"
"type": 147,
"typeName": "BTMParameterQuantity",
"message": {
"units": "",
"value": 0.0,
"expression": "-0.25 in",
"isInteger": false,
"parameterId": "mateOffsetDistanceZ",
"nodeId": "J+LuPhxB+1t4vnYa"
"type": 144,
"message": {
"value": true,
"parameterId": "limitsEnabled",
"nodeId": "ZKIZpuNWOeRbZ0dM"
"type": 807,
"typeName": "BTMParameterNullableQuantity",
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"expression": "0 deg",
"isInteger": false,
"parameterId": "limitAxialZMin",
"nodeId": "KVXmU7kM3+EMaFjq"
"type": 807,
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"expression": "45 deg",
"isInteger": false,
"parameterId": "limitAxialZMax",
"nodeId": "OxNBRDEYP++UdZT8"
"type": 144,
"message": {
"value": true,
"parameterId": "primaryAxisAlignment",
"nodeId": "Af/1L8J6jK45NqU/"
"type": 145,
"message": {
"enumName": "Reorient secondary axis",
"value": "PLUS_X",
"namespace": "",
"parameterId": "secondaryAxisAlignment",
"nodeId": "It64Nf/o+SfvHv/S"
"suppressed": false,
"namespace": "",
"subFeatures": [],
"returnAfterSubfeatures": false,
"suppressionState": {
"type": 0
"nodeId": "MHRrbsJgjRWu3+Iaf"
"featureStates": [
"key": "MHRrbsJgjRWu3+Iaf",
"value": {
"type": 1688,
"typeName": "BTFeatureState",
"message": {
"featureStatus": "OK"
"isComplete": true,
"serializationVersion": "1.1.16",
"sourceMicroversion": "e6688ceaaf1f929e8d0bcd47",
"rejectMicroversionSkew": false,
"microversionSkew": false,
"libraryVersion": 0
6
"type": 64,
"message": {
"version": 2,
"parameters": [
"type": 145,
"message": {
"namespace": "",
"type": 144,
"message": {
"value": true,
"type": 147,
"message": {
"units": "",
"value": 0.0,
"isInteger": false,
"type": 144,
"message": {
"value": true,
"type": 807,
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"isInteger": false,
"type": 807,
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"isInteger": false,
"type": 144,
"message": {
"value": true,
"type": 145,
"message": {
"value": "PLUS_X",
"namespace": "",
"namespace": "",
"subFeatures": [],
"type": 0
"featureStates": [
"value": {
"type": 1688,
"message": {
"isComplete": true,
"libraryVersion": 0
6 -
Thanks a lot!0
