Featurescript: type checking
jrs_spedley
jrs_spedley Member Posts: 71 ✭✭
Just a quickie, I can find an isInteger function and an isReal function (with bounds) but it seems they are more for 'features' rather than programming.  Is there a way when parsing an array to check what data type each element is, i.e. isBox, isArray, isString etc?
  • Jake_Rosenfeld
    edited April 2019
    @jrs_spedley
    You can use `is <type>` for this.
    Example:
    for (var item in someArray)
        if (item is box)
        else if (item is number)
        else if (item is ValueWithUnits)
    Same syntax as the `is` syntax for typechecking function parameters:
    function doSomething(context is Context, id is Id, definition is map)
  • Jake_Rosenfeld
    A word of caution as well.  Types have hierarchy and all non-builtin types (UpperCaseTypes) are built on top of builtin types (lowercasetypes).  Two specific examples are that a Vector is actually just a special array, and a ValueWithUnits is just a special map.
    So if you do:
    if (item is Vector)
    else if (item is array)
    or
    if (item is map)
    you will never actually hit the second block of execution.
    To check what builtin type a certain Type is based on you can search the standard library for `export type <TypeYouAreCuriousAbout>`:
    Here you can see that a Vector is just an array with nonzero size.
  • jrs_spedley
    Doh, do I feel dumb now!  That didn't even cross my mind, I just assumed it was for specifying parameters rather than an actual function.
    Thanks for super swift response.  I'll go and change everything back now as I've just changed all my arrays into boxes as a work around!  :)
  • Jake_Rosenfeld
    You're welcome!
