How to shadow in drawings
I have been trying to figure out how to shadow these letters in Onshape for 3D printing actual emblems like this one. This is just an example.
https://cad.onshape.com/documents/67386c56d5577664672e2f4e/w/e4c9645cb3131fc566e5da7f/e/1c9d805f9749d79ca4193b2e
It looks like you could use sketch text and then extrude with draft? Then create a base plate below?
https://cad.onshape.com/documents/79e5850722bf205d7fac2cf5/w/03d3c357211643aa6731047c/e/7a01b7923cd7c168922f888f
See document here
You can try the ExtrudeInDirection FS developed by some Onshape folks ( @lana, @Tim_Fries ).
https://cad.onshape.com/documents/95b6b10616fa81d9419fcdd2/v/5e7ee41b4f8366b40b835f1b/e/c29448656f30372b1d04a5f7?jumpToIndex=8300
Allows you to select an extrusion direction (like SolidWorks extrude) and, of course, draft.
Also, when selecting those edges for draft, don't forget the time-saver "create selection":
thanks for the link to ExtrudeInDirection; helpful to know about. And the reminder on Selection!
In my trials the extrusion is good for the effect OP is after, but getting draft to work is another matter.
