Mute objects through featurescript
You can just delete them at the end of the feature using opDeleteBodiesIlya Baran \ VP, Architecture and FeatureScript \ Onshape Inc7
But how? How do you delete a cruve created with line(...,...) for example?
Example:
fCuboid(context, id + "cuboid1", { "corner1" : vector(0, 0, 0) * inch, "corner2" : vector(1, 1, 1) * inch }); opDeleteBodies(context, id + "deleteBodies1", { "entities" : qCreatedBy(id + "cuboid1", EntityType.BODY) });This creates a cube and then deletes it. Note that the first call has id + "cuboid1" and that id is used in a qCreatedBy query to then delete the geometry.0
