fail with the video card
Luis_Rodríguez
Member Posts: 2 ✭
Hello,
I htave a problem with Onshape, and i think that the problem is the video card.
I have to buy a new one and I have see this:
GIGABYTE 1030 OC 2G
with this card Onshape works ok.
Thanks
GIGABYTE 1030 OC 2G
Thanks
Welcome to the forum and Onshape Luis
There could have just been an issue with WebGL, or a bad driver with the old card.
Onshape is fairly forgiving on GFX card requirements.0 -
Hello Luis,
Can you open this page : https://cad.onshape.com/check on the machine with the problem video card? We also have troubleshooting tips here : https://cad.onshape.com/help/Content/webgl.htm?cshid=webgl
Hello Paul,
In firts time the report of my browser is compatible but in the second report appear the next information. I have tested in 32 and 64 bits.
My video card is
Radeon X1300/X1550 Series (Microsoft Corporation - WDDM)
ThanksUser agentMozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36 OPR/58.0.3135.132PlatformWindowsBrowserOperaBrowser Version71.0.3578.98WebGL and extensions
Core WebGL
Float textures
Float textures are used for section planes and blending of transparent objects. Without this extension, this functionality will be disabled.Anisotropic texture filtering
Anisotropic texture filtering is used to provide high-quality texture rendering in the 3D scene.32-bit indices
32-bit indices are used to optimize rendering performance. Lack of 32-bit index support may result in decreased rendering performance.High precision fragment shaders
High precision shaders are required for ambient occlusion. If they are not available, this functionality will be disabled.Your browser does not have WebGL enabled.
Click here to learn more about the system requirements.WebSockets
WebSocket connection
Geographical data
LocationBarcelona, SpainOnshape server regioneu-west-1Expected server regioneu-west-1
Report
Download report
Hello Luis,
Looks like you are using Opera and WebGL is not being supported. This could be due to the graphics card and the browser. Can you open this page to test for WebGL support : https://get.webgl.org/ . If you don't see a spinning cube, then the issue is definitely with the browser + GPU you are using.
If you don't get WebGL with your browser
1. Can you try another browser such as Chrome or Firefox?
2. You'll want to check out the Opera forums to determine why your GPU isn't supported?
3. Ensure you have the latest version of the graphics drivers installed.
4. As a last resort you'll need to get a newer graphics card.
Paul0
