Adding a Surface to the main Part
chumachuma Member Posts: 4
[I'm relatively new to Onshape, so I'm probably CADing this the wrong way.
I'm trying to make a lip on a cup edge. When I use the Fill feature, it creates a completely new surface (in white) - is there a way to merge this new surface with the original part?
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    Can you share your document so we can see the workflow you have taken to get to where you are? Will be easier to provide advice. If it's a public document, just post the link here.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 261 image
    I created two examples similar to the image above. One approach is using the loft and fill surface commands, the other using a solid extrude cut. You could also use a revolve cut but I am assuming that the cut profile needs to be uniform through the part.
    https://cad.onshape.com/documents/af35af5236ef264a88f0ccc0/w/fb7376495e299e9cddb9b9bf/e/04dff67e242e0ad5d1a600ec
    Extrude cut at angle
    Split face, delete face, loft and fill Surface
  • chumachuma Member Posts: 4
    Thanks for the note, Cris. First timer here, will link it next time.
    These look great, thank you for taking the time to do this!
    I love the loft solution - my big issue was that my initial revolve feature was rendered as a surface instead of a solid and then I couldn't do an extrude cut for some reason. Thanks again.
