Assembly Configurations for Cabinet Drawer Combinations
famadorian
Member Posts: 390 ✭✭✭
Is it possible to use assembly configurations for different drawers configurations in a cabinet? I'm sure I can hack it together, but is this the right way?
This one's a bit tricky, cause it's not just the number of drawers, but configurations could be 40 drawer + 10 drawer + 10 drawer + 20 drawer for one cabinet and lots of other combinations;)
The short answer is yes
The full answer was becoming a book.
I'll make a video walkthru instead when i get back from lunch
This ended up taking a couple of attempts to get something I was happy with.
I will give a walk thru video later, Wife was taking a nap and don't want to talk in the house right now.
Here is a link to the document:
https://cad.onshape.com/documents/80a156f834ded85fa552cb74/w/74aad4aa9a0916fd34542867/e/654720b5c2c364633ed85922
Here is a video demo:
https://www.youtube.com/watch?v=zpY9XfKUmyY
I need time to process all this information, but thank you a lot
1 -
Ok, I've managed to use your wisdom to create my own cabinet;)
However, it doesn't seem to want to be inserted into an Assembly.
I tried with yours aswell.
It generates, but then doesn't get inserted into the assembly.
Does it insert for you?
My bad; it's inserting;)
Hehe, this is fantastic.
Thank you so much for this thorough explanation; it was quite a ride;)
Here's my version:
https://cad.onshape.com/documents/73a87f3825c877243eb21d4c/v/ee0a3ac7b3470f44e97fd43c/e/315868911494a97cb32c3025?configuration=List_1Qz6HGuNYWBvWm=_10;List_7zopikdoFSoUMc=_20;List_ImnZsUtSFXDUj6=_10;List_RcpJgkGh84q8Hr=_10;List_qQmj4TPNTGE3Gp=_10;List_xXGM9ejsAILG4X=_20
Hard to say right now, i'm on the muskegon river, not strong enough signal to check. I did only get the blue cabinet only when i used the mobile app.. so not sure0
No worries, I got it; have a good one;)0
Glad I could help0
Ok, trying now to take it to the next level;)
Each cabinet also has varying width, 200, 400, 600, 800 and 1000;)
I'm getting visions of pain here;)
I can't just use a simple configuration for width here, cause all drawers are also changing width;)
This is upping the ante.0 -
it's pretty close to the same problem, i'll sketch up an example once i'm by my computer again0
To be clear, you need the cabinet to have multiple drawers in hight and width.
Each drawer will have independent height and width0 -
like this?
No, that's too complex
I just want 200, 400, 600, 800 and 1000mm wide cabinets
Height is always 800mm.
This is IKEA METOD basically
Drawers are always 100, 200, 400, 600 and 800mm tall
https://cad.onshape.com/documents/80a156f834ded85fa552cb74/w/eb9a2a528a80cb3b45977f57/e/051b34155677c14b0c9fc239
Check this out and tell me if I under stood you right0 -
Indeed;) Ok, I think I got it; I will try. Thanks0
Here is a modular cabinet model we built. It is still in progress, but may help you out!https://forum.onshape.com/discussion/13883/modular-cabinet-model-showing-off-model#latest
https://www.youtube.com/watch?v=7vjhPT0xgpQ
