Strange value for no max axial limitation of a mate
C_Justin
C_Justin Member Posts: 16 ✭
edited May 2019 in Community Support
I have this block of json returned by the api. It's really strange since the mate is a revolute mate and I didn't set any limitation on Z axis rotation, but the json seems says the value is not null. Also, the value is 0 deg for maximum but in the document, the mate seems to have the freedom to rotate 360 degrees. I'm confused about the default value of each limitation.
        "type" : 807,
        "typeName" : "BTMParameterNullableQuantity",
        "message" : {
          "isNull" : false,
          "nullValue" : "No minimum",
          "units" : "",
          "value" : 0.0,
          "expression" : "0 deg",
          "isInteger" : false,
          "parameterId" : "limitAxialZMin",
          "hasUserCode" : false,
          "nodeId" : "nDu/OIODp1wkH+Fl"
        "type" : 807,
        "message" : {
          "isNull" : false,
          "nullValue" : "No maximum",
          "units" : "",
          "value" : 0.0,
          "parameterId" : "limitAxialZMax",
          "nodeId" : "hpo8dGfqMupMcyDl"
