How do I print multiple drawings ??
paul_bartlett
paul_bartlett Member Posts: 98 ✭✭
I have 6 drawings in 6 tabs. Can I print them all at once? I do not see a place to add sheet to a single drawing that is why I have six tabs. I know I must  be missing something very basic.
  • Cris_Bowers
    Cris_Bowers Member Posts: 281 PRO
    You're missing something. On the sheets flyout (ctrl+s) the little button at the top right is how you add more sheets.
  • brucebartlett
    Muli sheet is a way to group and print multiple drawings but I prefer to create my drawings as separate tabs to enable url linking and more granular release and versioning. It would be really nice to be able to select and print multiple drawing tabs in 1 go but unfortunately, this is not available yet.
  • patrick_farley
    patrick_farley Member Posts: 37 ✭✭
    I got the same issues, this is what prevent us to completely go with Onshape.
    The probleme is we have a multipart machine, and a lot of part are reuse from one machine to another (Common parts) , so we would like to keep the same part no, and not have to manually export to PDF all the common part manually when we want to send the part to a machine shop.
    We would not like to add a sheet for all the commun parts in every machine that we build
    If there would be a wait to export the whole BOM to pdf, or any other tricks
    Any news on this?
    Pat Farley
  • john_mcclary
    Perhaps with the API. This could be done. But not with vanilla Onshape.
    I know some here that have set up on online configurator that spits out a pdf. So it should be doable to an extent.
    P. S. I'm not an api developer... Sorry
