Beams 2.0 error
Dmitry_Golovkin
Member Posts: 22 ✭✭
Hi Guys,
Recently I started to experience problems with Beams FeatureScript. When I try to pull the manipulator arrow to reposition the beam it started to report error. Probably it started after the latest update FS but I'm not sure. FeatureScript notice does not report anything. It does not depend on profile. Can't find way to workaround. I use Official V8 version.
Document URL is https://cad.onshape.com/documents/b4cbf1e8ad2a900ecfcec7c4/w/440ac939c042138bc444207d/e/1ac794b7d7d543e6138441a3
Any ideas would be appreciated.
Admittedly, there have been a few reports about this. Official V5 is the one that has been there for the past year. V6, V7 and V8 were all made on the same day. I’ve looked at the code and can see nothing that I’ve changed that would affect the regeneration of the feature. I have also seen the feature somehow fix itself (when the original doc has been shared with support). I will take another look. Although the blue link icon may be annoying, you should continue to use V5 until I can get to the bottom of this. Sorry for the inconvenience.Senior Director, Technical Services, EMEA5
This should be fixed now. Please post if you see that behavior again.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc6
I can't reproduce the error - I don't think the Beams feature is at fault. Can you try Beams Official V5 and see if you still get the error? Otherwise, please contact support (via Help > Report a Bug) and share your Document.Senior Director, Technical Services, EMEA0
It happens not with all the beams. Some work fine some not. V5 works fine where V8 does not work. I believe the problem is in the script.0
I have the same problem as @dmitry_golovkin .Beam 2.0 works perfect in new Documents.Beam script up to v6.0 works ok in old documents (old I mean pre-V7.0 script).So I had to downgrade beam script back to v6.0 in my old documents.0
Thank you Neil,
I have contacted to support as you advised.0 -
Official V9 version of the Beams feature is now available. Please update any V8 features to V9 (old V5 features can be kept as-is) and let me know if you run into any more trouble.
@Dmitry_Golovkin I have tested it in your Doc and it works (I also tested it in another user's Doc which was displaying the same behaviour).
Senior Director, Technical Services, EMEA2 -
Hi Neil,
Everything is working fine after update to V9.
Sorry that's not all ). In one my document everything become ok but in other one the problem still exists.
It didn't marked outdated scripts. I updated everything manually. The first I updated script in toolbar after that every instance one by one. It didnt show blue chain. In one document it worked in another one it didn't.
Thank you @NeilCooke ,I updated beam features to V9 and all work fine now.0
Ok, i've find out what was the problem.
For some reason each beam picked up custom profile sketch older version than "main". After I manually linked the latest sketch to each beam everything started work properly.0 -
I'm really confused. Sometimes it works fine sometimes buggy. Can't find any correlation.0
It's not working randomly. Sometimes it's working when I open document sometimes it's not. If it's not working its about all the beams regardless if it custom profile or standard one.NeilCooke said:@Dmitry_Golovkin so V9 is not working?0 -
@Dmitry_Golovkin I’ve had another look at your doc and can confirm it’s not working as it should. There is more going on here than meets the eye and I need to get a developer to look at it. In the meantime please use V5 of beams. My sincere apologies for all the hassle, hopefully we can get this resolved soon.Senior Director, Technical Services, EMEA0
Could it be caused by Russian version of Windows? I tried to play with system locale and other regional settings but nothing helped.NeilCooke said:@Dmitry_Golovkin I’ve had another look at your doc and can confirm it’s not working as it should. There is more going on here than meets the eye and I need to get a developer to look at it. In the meantime please use V5 of beams. My sincere apologies for all the hassle, hopefully we can get this resolved soon.0 -
No, not at all.Dmitry_Golovkin said:Could it be caused by Russian version of Windows? I tried to play with system locale and other regional settings but nothing helped.Senior Director, Technical Services, EMEA0 -
Thanks Ilya, everything's working fine for both the documents.0
