New Video: Learn how to make a Nut
Hello Onshape Users.
Onshape marketing team member Ethan Rejto has created a great new video on how to make a nut, with a high level of detail.
Check it out by clicking http://bit.ly/OnshapeNUT
You raise an interesting point. I would rather see it resolved slightly differently, though.
There is a big advantage attached to NOT specifying the length of a helix numerically: a surface can be defined so it can adapt to future model changes which affect that length. I would hate to see irreplaceable functionality like this sacrificed for the sake of minor convenience.
It might be better (if you don't want to create a surface) if Onshape were to add an "extend to next face" option for sweeps, so that the extra step is not needed. In the meantime, those not wishing to create a surface can use "Delete face" to extend the thread through the nut ... although I realise that it's a bit fiddly picking the face to delete.
you're welcome. I think the correct name of the option as implemented in SW is actually "Align with end faces" - indicating that it works at both ends of the sweep (when it works, which is not always)
Naturally, there are some paths which are not able to be automatically extended, and some cases where they can, but the resulting sweep becomes self intersecting or does not terminate cleanly.... so the option does not always work as expected.
If Onshape decide to implement a similar option, I reckon it would be a good improvement to design it so that it was possible to selectively apply it to the start or the end separately, firstly in the event where one end failed but the other succeeded, and secondly because it might reflect the design intent, to extend only in one direction.
