Sketching in FeatureScript - Coincident constraint between two vectors
nkone
nkone Member Posts: 3 ✭
I'm currently learning how to sketch in FeatureScript. I want to know if there's a way to sketch with constraints before using skSolve. For example if I want to make a tangent arc with its two end points coincident to two end points of a pair of parallel lines. The arc has to be tangent with both lines. Is there an easy way for me to use the coincident constraint? (beside using the built-in tool). I know FeatureScript is not meant for sketching with constraints. I tried reading the documentation as well, but there is little there. Any work around would be appreciated.
This is what I got so far.
