evRaycast not reporting all face intersections
Cappie_Pomeroy
Cappie_Pomeroy Member Posts: 14 ✭
I'm trying to use evRaycast to get all points where a ray intersects the face of a body.  It mostly seems to be working however I have run into a strange issue.  A single point is missing from what I would expect to be an intersection.  I've included a screenshot where I have circled the "expected point" in black and a link to a document with a simplified version of my script that has the same issue.  Anyone have any insight into this?  Possible workarounds perhaps?  It appears that I can get the point as an EntityType.EDGE intersection.  I want to filter by FACE because  otherwise I end up with a lot of very close duplicate points in the RaycastResult of EDGE as expected.  I would like to avoid filtering in a more computationally intensive way because eventually I will be iterating over thousands of rays.
Document Link:
Thanks!
Cappie
  • MBartlett21
    @Cappie_Pomeroy
    I also noticed that for edges, it only gives the first intersection with each edge, so if the edge crosses the line twice, it only returns one intersection
    IR for AS/NZS 1100
  • Konstantin_Sh
    Konstantin_Sh Member Posts: 26 ✭✭
    edited July 2019
    I think evRaycast still uses evDistance internally iterating through the list of faces and giving the result with the closest positive parameter so it is not suprizing that it can't find multiple intersections within same face just like evDistance. At least it gives similar perfomance results comparing to that algorhytm.
  • mthiesmeyer
    mthiesmeyer Onshape Employees Posts: 115 image
    @Cappie_Pomeroy,
    It looks like it may potentially be a tolerance issue. I wiggled your z value by .000001 and got your expected results.
    Best,
    Mike
  • MBartlett21
    @mthiesmeyer
    I was trying evRayCast with a spline that intersected the line twice, but it only gave the closest result, even when 'closest' was set to false
    IR for AS/NZS 1100
  • _anton
    _anton Member, Onshape Employees Posts: 555 image
    @Cappie_Pomeroy
    Hey! It looks like I can get all correct intersections if I cast rays on just faces instead of the entire part, i.e., using
    qOwnedByBody(definition.part, EntityType.FACE)
    instead of definition.part. Then you won't have to filter, either.
  • Cappie_Pomeroy
    @MBartlett21 I haven't experimented too much with the edges because I am interested in intersections at an arbitrary plane that I choose so I wont always have an edge.  I did notice the same behavior you're describing though.
    @Konstantin_Sh I just found it odd that it was inconsistent in the multiple intersection points that it did find.  That one just doesn't seem particularly special in any way.
    @mthiesmeyer I noticed that also, but I am interested in tolerances on the order of 1um so I was hesitant to use that workaround and was hopeful of another way.
    @Anton_Bovin That's a great work around!  It works exactly as expected.
    Update for everyone Onshape has flagged this as a bug and are working on it.  I'll try to remember to post back to this forum when it's fixed.
