"HOLE FEATURE FAILURE"
D8_StarpacD8_Starpac Member Posts: 49 ✭✭
While Creating a Hole in a Hallow shaft or Hallow Block,I am using "BLIND" Feature in "PART STUDIO" but The feature will Consider as a "THRU" in "DRAWING" .Please Upgrade that feature.
  • StephenGStephenG Member Posts: 384 ✭✭✭
    If the Blind distance given produces a completely through hole in the part then the Hole Callout annotation will treats it as a through hole condition. Check the Blind distance value to make sure it doesn't result in a through hole through the part.
