Any way to identify rebuild errors for all configurations at one time?
tim_hess427
tim_hess427 Member Posts: 648 ✭✭✭✭
I'm currently working on a model with a fairly large number of configurations. Is there any way to see, at a glance, which configurations have errors? It can be pretty time-consuming to go through all of these different configurations and chase down any problems.
  • tim_hess427
    @philip_thomas and @Jake_Rosenfeld -  Good point! I did not think about that.
    What about some sort of "debug" function where you could select a limited number of configurations to check on-demand as opposed to checking every time a change to the model is made?
    As a work-around, I did notice that I can open multiple browser tabs and keep a different configuration open in each one. I don't keep every configuration open, but did open up a few "test" cases to catch big things early. At some point, I'll still need to manually cycle through each configuration, though.
