Improvement not improved - Project Curve to Surface
mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
This improvement request for projecting sketches onto a surface was just closed, but it's not actually resolved. You can now wrap a sketch on cylindrical surfaces, but that's it. You can't project a sketch on any 3D surface as the improvement request specified.
https://forum.onshape.com/discussion/8335
  • lanalana Onshape Employees Posts: 761 image
    Ability to imprint sketch curves on faces was added a long time ago - see split Face option
    It is not the same as your improvement request, but might be a work-around in meantime.
    It's a workaround, but I suppose it will do. Thanks.
