Variable Fillet FS
tabetha_bulnes
tabetha_bulnes Member, Developers, HON-TS Posts: 38 PRO
I am trying to use a variable fillet in my featurescript. I have found that the issue was in the vertexsettings array. I tried to duplicate the std fillet code that contains the vertexsettings but I still receive an error. Can you please help me understand where the issue is with the vertexsettings array? When I use the show code function and review OS Variable Fillet I see that our vertexsettings are mostly identical so I am not sure where the issue is within the vertexsettings.
FeatureScript 1135;
export import(path : "onshape/std/geometry.fs", version : "1135.0");
const POSITIVE_EDGE_BOUNDS =
            (unitless) : [0, 0.5, 1]
        } as RealBoundSpec;
        const VR_BLEND_BOUNDS =
    (meter)      : [0, 0.005, 500], //allows zero
    (centimeter) : 0.5,
    (millimeter) : 5.0,
    (inch)       : 0.2,
    (foot)       : 0.015,
    (yard)       : 0.005
} as LengthBoundSpec;
const T_BLEND_BOUNDS =
    (meter)      : [0, 00005, 500], //allows zero
    (centimeter) : 0.5,
    (millimeter) : 0.5,
    (inch)       : 0.2,
    (foot)       : 0.015,
    (yard)       : 0.005
const FILLET_RHO_BOUNDS =
    (unitless) : [0.0, 0.5, 0.99999]
} as RealBoundSpec;
annotation { "Feature Type Name" : "T-Variable Fillets" }
export const TVarFill = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Entities to fillet",
                    "Filter" : ((ActiveSheetMetal.NO && ((EntityType.EDGE && EdgeTopology.TWO_SIDED) || EntityType.FACE))
                                || (EntityType.EDGE && SheetMetalDefinitionEntityType.VERTEX))
                        && ConstructionObject.NO && SketchObject.NO && ModifiableEntityOnly.YES,
                    "AdditionalBoxSelectFilter" : EntityType.EDGE }
        definition.entities is Query;
         annotation { "Name" : "Tangent propagation", "Default" : true }
        definition.tangentPropagation is boolean;
        annotation { "Name" : "Cross section", "UIHint" : "SHOW_LABEL" }
        definition.crossSection is FilletCrossSection;
        annotation { "Name" : "Radius" }
        isLength(definition.radius, BLEND_BOUNDS);
        if (definition.crossSection == FilletCrossSection.CONIC)
            annotation { "Name" : "Rho" }
            isReal(definition.rho, FILLET_RHO_BOUNDS);
        else if (definition.crossSection == FilletCrossSection.CURVATURE)
            annotation { "Name" : "Magnitude" }
            isReal(definition.magnitude, FILLET_RHO_BOUNDS);
        annotation {"Name" : "Variable fillet"}
        definition.isVariable is boolean;
        if (definition.isVariable)
            annotation { "Name" : "Vertices", "Item name" : "vertex",
                        "Driven query" : "vertex", "Item label template" : "[#vertexRadius] #vertex" }
            definition.vertexSettings is array;
            for (var setting in definition.vertexSettings)
                annotation { "Name" : "Vertex", "Filter" : ModifiableEntityOnly.YES && EntityType.VERTEX && ConstructionObject.NO && SketchObject.NO,
                            "MaxNumberOfPicks" : 1 ,
                            "UIHint" : "ALWAYS_HIDDEN" }
                setting.vertex is Query;
                annotation { "Name" : "Radius", "UIHint" : "MATCH_LAST_ARRAY_ITEM" }
                isLength(setting.vertexRadius, VR_BLEND_BOUNDS);
                    annotation { "Name" : "Rho", "UIHint" : "MATCH_LAST_ARRAY_ITEM" }
                    isReal(setting.variableRho, FILLET_RHO_BOUNDS);
                    annotation { "Name" : "Magnitude", "UIHint" : "MATCH_LAST_ARRAY_ITEM" }
                    isReal(setting.variableMagnitude, FILLET_RHO_BOUNDS);
         debug(context, definition.vertexSettings);
opFillet(context, id + "fillet1", {
        "entities" : definition.entities,
        "tangentPropagation" : true,
        "crossSection": definition.crossSection,
        "radius": definition.radius ,
        "rho" :definition.rho,
        "magnitude": definition.magnitude,
        "defaultsChanged" : false,
        "isVariable" : definition.isVariable,
        "vertexSettings": definition.vertexSettings
  • Jake_Rosenfeld
    @tabetha_bulnes
     Could you post a screenshot of the error that is happening?  Is it an error at regen time, or an error in the Feature Studio?  In either case it may help to open the console (by pressing the button that looks like a check mark between two curly braces, at the top right of the page)
    Also, there is a handy "code" box that you can paste code into on this forum to make it more readable.  Just click the paragraph icon to the right of the bullets icon while writing your forum post, and click the "code" option in the dropdown.  A yellow box will show up that you can paste your code into!
    // It will then show up like this!
  • tabetha_bulnes
    @Jake_Rosenfeld
    I have added the code below that produces a Regen error. As soon as I select the first vertex point I receive the Regen error.
    https://cad.onshape.com/documents/89ea5b04ab0d940258f2c284/w/9a648584769c66b27bffe8e4/e/a7fbeb90da4045975014fb1d
  • Jake_Rosenfeld
    @tabetha_bulnes
    Is it possible to make the document public instead of just link shared?  I don't see anything in the console, which is a little suspicious, so I would like to make my own copy to play around with and diagnose.
  • tabetha_bulnes
    @Jake_Rosenfeld
    I have made the file public now. Thank you for your help! :)
  • Jake_Rosenfeld
    edited September 2019
    @tabetha_bulnes
    The operation is failing because the "smoothTransition" field needs to be supplied to opFillet.  It should be a boolean, and corresponds to that same field in the fillet dialog.  It looks like this is not documented, so I will log something to improve that!
  • tabetha_bulnes
    @Jake_Rosenfeld
    That did it! Thanks! You guys are awesome! :smiley:
