Adding 3D points failing. What options?
in General
Trying to use 3D Point ( FS 3D PointV 2.4) to add points with the 'Along Path' option. It works on sketch curves but not 3D curves like Bridge or 3D spline or surface boundary. Is there a newer version or other idea on how to place points along 3D curves?
getting this error message from above FS -
"Did not generate properly. Invalid input selections."
www.accuratepattern.com
Could you give a link to a public example please?
IR for AS/NZS 1100
Thanks for looking into this! Great to have this FS till OS has capability. I have a handful of failure examples all on 3D created curves. On my real job percentage on Surface Boundary was failing but been unable to reproduce. Distance does fail.
3D Point tests
It is fixed now
I was expecting
constructPath
to explode bodies into the edges owned by each body, but it didn't, so I have fixed it up.IR for AS/NZS 1100
