Convert to sheetmetal
bryan_lagrange
Member, User Group Leader Posts: 976 ✭✭✭✭✭
in General
Fusion 360 just added the one click convert to sheetmetal command. I would love to see this in Onshape.
Onshape has a third party sheet metal command alternative that indeed includes a convert option for existing models. However, I often have to manually remove fillets and use its Thicken option instead after selecting only the outer surfaces. Rhino models are notorious for having glitches even when exported as Parasolid files.
https://cad.onshape.com/documents/a39db7615a2a945ffb7076c3/v/2212f034dcd5e9a02a857ad6/e/279e25dcd74a1b2eafeba514
