index of item in array
morteza_karimi
morteza_karimi Member Posts: 13 ✭
Is there something similar to indexOf() method of javascript that returns the index of a given item in an array?
  • konstantin_shiriazdanov
    you can look at source code of isIn() builtin function of standard library and modify it to return the index instead of boolean
  • MBartlett21
    Here is an example function:
    function indexOf(value, arr is array) returns number
        for(var i = 0; i < size(arr); i += 1)
            if(value == arr[i])
                return i;
        return -1;
    IR for AS/NZS 1100
