Spring_GeneratorFS question
tonvis
tonvis Member Posts: 41 ✭✭
edited November 2019 in Community Support
Can please someone help me out, I am struggling getting the result as shown PartStudio1
PartStudio2 ->
            /** @ NeilCooke You can't pick out a specific sketch entity using id + "arc2" (that does not exist as it is part of id + "sketch7"). If you only want one edge from a sketch,
               sketchEntityQuery (operationId is Id, entityType, sketchEntityId is string) returns Query
               Gets the wire body entities created for a specific sketch entity.
               If the sketch id created multiple sketch entities, will return all the wire bodies.
            /* ------------------- this part is working OK
               opSweep(context, id + "sweep4", {
               "profiles" : sketchEntityQuery(id + "sketch8", EntityType.EDGE, "flat"),
               "path" : sketchEntityQuery(id + "sketch7", EntityType.EDGE, "arc2")
            /*  ------------------ Why does this not generate multiple edges like  PartStudio1  ??
               "path" : qUnion([
               sketchEntityQuery(id + "sketch7", EntityType.EDGE, "arc2"),
               sketchEntityQuery(id + "sketch7", EntityType.EDGE, "line2"),
               sketchEntityQuery(id + "sketch7", EntityType.EDGE, "helix4"),
               sketchEntityQuery(id + "sketch7", EntityType.EDGE, "line1"),
               sketchEntityQuery(id + "sketch7", EntityType.EDGE, "arc1")
             */            /*  ----------------------  Why does this not generate multiple edges like  PartStudio1  ??
               "path" : qCreatedBy(id + "sketch7", qEverything(EntityType.EDGE))
I like Onshape very much, and am  interested learning Feature Script, but lack on examples makes it really difficult to keep up,
but never give up.
Thanks the Onshape support team.
