Feature script CANNOT_RESOLVE_ENTITIES error
joe_gatling
Member Posts: 3 ✭✭
Hello, I am very new to feature script I am writing a feature script that will automatically add holes to a part at a fixed spacing. The goal is to pass a line along which the holes should be cut, and the spacing desired and have the script decide how many holes will fit, and how to center them along the line. I have the logic of the hole placement working, but the final boolean to actually subtract them from my part is giving me a "CANNOT_RESOLVE_ENTITIES" error. I am pretty advanced in other programming languages like c#, but the concepts involved in FS are really giving me a headache.
The document I am working on is here: https://cad.onshape.com/documents/1bf535513ae3dcbf66a9e1ae/w/949a41da612184a3bb92d3ac/e/1fb9668c48c8b413d51dc58b
When regenerating, the opBoolean line at the bottom throws the error. Any help would be appreciated.
The code is as follows:
FeatureScript 1150;
import(path : "onshape/std/geometry.fs", version : "1150.0");
annotation { "Feature Type Name" : "Connection Holes" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Hole Diameter" }
isLength(definition.holeDiameter, LENGTH_BOUNDS);
annotation { "Name" : "Hole Depth" }
isLength(definition.holeDepth, LENGTH_BOUNDS);
annotation { "Name" : "Spacing" }
isLength(definition.spacing, LENGTH_BOUNDS);
annotation { "Name" : "Edges", "Filter" : EntityType.EDGE && GeometryType.LINE}
definition.lines is Query;
annotation { "Name" : "Merge scope", "Filter" : EntityType.BODY && BodyType.SOLID }
definition.mergeScope is Query;
const lines = evaluateQuery(context, definition.lines);
for (var line in lines)
var length = evLength(context, {
"entities" : line
var numberOfHoles is number = floor(length / definition.spacing);
var tPerHole is number = definition.spacing / length;
var remainingT is number = 1.0 - (tPerHole * numberOfHoles);
// debug(context, "Length: " ~ length);
// debug(context, "Holes: " ~ numberOfHoles);
// debug(context, "t Per Hole: " ~ tPerHole);
// debug(context, "test: " ~ (remainingT + (tPerHole * numberOfHoles)));
var sketchPlane = evOwnerSketchPlane(context, {
"entity" : line
var normal = sketchPlane.normal;
var baseId is Id = id + "cylinder";
for(var i = 0; i <= numberOfHoles; i += 1)
var t = remainingT/2.0 + tPerHole * i;
var point = evEdgeTangentLine(context,
"edge" : line,
"parameter" : t
}).origin;
fCylinder(context, baseId + i, {
"topCenter" : point,
"bottomCenter" : point - normal * definition.holeDepth,
"radius" : definition.holeDiameter/2.0
debug(context, qCreatedBy(baseId, EntityType.BODY));
opBoolean(context, id + "boolean1", {
"tools" : qCreatedBy(baseId, EntityType.BODY),
"targets" : definition.mergeScope,
"operationType" : BooleanOperationType.SUBTRACTION
OMG. Never mind. I turns out I didn't have any entities defined in definition.mergeScope so there were no targets to subtract from.
1
1
