Fillet without trimming
Is there any way to create a fillet while sketching without trimming the corner?  I'd like to leave the corner there in some cases.
  • tim_hess427
    tim_hess427 Member Posts: 648 ✭✭✭✭
    You could just add an arc, then dimension the radius and add tangent constraints. Or you could add a circle, add the same constraints, then trim the portion of the circle you don't need.
    Or... you could leave the corners as-is and add the fillets to the 3D part instead of doing it in the sketch.
    Several different options - just depends on your needs!
