ECAD Import Option
Several years ago there was an app that allowed you to import ECAD files into Onshape. When that app was removed I seem to recall getting an email from @joe_dunne saying that the app was no longer available but another solution was coming soon. Currently I don't see any way to import ECAD files.
Is there a solution out there? Is one on its way?
Thanks!
Christopher
  • Ethan_KEthan_K Member, Onshape Employees Posts: 57 image
    edited October 2019
    Hi @christopher_quijano,
    This app is under development. @rob_lacey might have more information on this? I found this thread - it may be of interest to you: https://forum.onshape.com/discussion/comment/19605#Comment_19605 .
    Thanks for asking!
    -Ethan
  • christopher_quijanochristopher_quijano OS Professional Posts: 50 PRO
    Thanks @Ethan_K but I could not find it in the App store.
    That's right - it is under development. @rob_lacey may have more information.
  • rob_lacey761rob_lacey761 Member Posts: 1
    @christopher_quijano - Apologies I didn't see this post earlier. Yup, I've got something that should do the trick at www.ecadmcad.com. It's still in Beta at the moment and currently free to use. Just create an account and give it a go. It supports IDF, IDX & Eagle (though I need to do a bit more work to ensure Onshape is able to cope better with disjointed profiles from Eagle). I'd certainly appreciate your feedback - you can get in touch with me via the 'Contact' page if you need anything. Thanks!
