Angular dimensions with only one arrow
ouilogique
Member Posts: 6 ✭✭
In a drawing, is it possible to draw angular dimensions with an arrow at one end only to indicate the direction of rotation?
Not sure that follows any drawing standards, but if it is simply the direction of rotation you need, you could add an arrow to your part by searching “FeatureScript Arrows” and adding the custom feature to your toolbar.Senior Director, Technical Services, EMEA0
Thank you for your answer. From what I saw, FeatureScript Arrows are 3D objects. What I need is a dimension in 2D. Here is an example:
Basicaly, the only thing I need is to remove the arrow at one end.0 -
They are 3D objects but you can add them to an assembly and a drawing (turn on the surface filter in the insert view dialog).Senior Director, Technical Services, EMEA0
Well, a simple checkbox to display or hide the arrows would be much easier...
1 -
indeed. Create an improvement request.Senior Director, Technical Services, EMEA0
