Creating a new Feature via API JSON Format (NodeJS)
maximilian_hansmaximilian_hans Member Posts: 3
edited October 2019 in App Store & Partners Apps
Hello everybody,
Don't know where else to post this question ,if there is a more appropriate location, please tell me =)
I'm currently trying to wrap my head around this, but I just can't get it to work. I am using NodeJS, but this is more of a general question (i guess).
I am trying to add a new feature to an existing document. For simplicity I want to declare a variable and I get back the following:
&nbsp; "moreInfoUrl" : "",<br>&nbsp; "message" : "Error in input",<br>&nbsp; "status" : 400,<br>&nbsp; "code" : 9999
The API docs read:
A feature can be added to the feature list by calling the add feature API. The API accepts as input a JSON structure containing the fields:
  • feature - A single feature definition, in the same format that is output by the get feature list API, except that there is no need to provide feature ids, node ids, or typeNames.
  • sourceMicroversion - The microversion of the document that is assumed. Any geometry ids included in the feature are interpreted in the context of this microversion.
  • rejectMicroversionSkew (optional) - If set to true, the call will refuse to make the addition if the current microversion for the document does not match the source Microversion. Otherwise, a best-effort attempt is made to re-interpret the feature addition in the context of a newer document microversion.
This is a bit vague for me - what exactly do I need? I am using the NodeJS example from github (Link) - the function I use to post is below.
When printing out an existing variable from the feature list I get the code below. How would a feature object have to look like to add a simple length variable?
  • I crossed out the parameters, that I think could be left out - is that correct?
  • Can I leave out even more?
  • What does the "type" parameter mean, is there a reference to get the different type-IDs?
  • Do I (in this case) have to send all the parameters (like for example the angleValues) eventhough I don't need them?
Copied Object:
<div>{ type: 134,<br>&nbsp; typeName: 'BTMFeature',<br>&nbsp; message:<br>&nbsp;&nbsp; { featureType: 'assignVariable',<br>&nbsp;&nbsp;&nbsp;&nbsp; featureId: 'FBDKLiWSFhxivCS_4',<br>&nbsp;&nbsp;&nbsp;&nbsp; name: '###name = #value',<br>&nbsp;&nbsp;&nbsp;&nbsp; parameters:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; [ { type: 145,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>typeName: 'BTMParameterEnum',</strike><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { enumName: 'VariableType',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; value: 'LENGTH',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; namespace: '',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'variableType',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: '1RAiTT9k/YZWmNgz'</strike> } },<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { type: 149,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>typeName: 'BTMParameterString',</strike><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { value: 'height',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'name',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: '2mqEuNkuTwd4X24B'</strike> } },<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { type: 147,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<strike> typeName: 'BTMParameterQuantity'</strike>,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { units: '',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; value: 0,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; expression: '20 mm',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; isInteger: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'lengthValue',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: 'oqr4JEGmAvo46VbB' </strike>} },<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { type: 147,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>typeName: 'BTMParameterQuantity',</strike><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { units: '',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; value: 0,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; expression: '0 deg',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; isInteger: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'angleValue',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: 'GimpgbFzb/8Z7IaC'</strike> } },<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { type: 147,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>typeName: 'BTMParameterQuantity',</strike><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { units: '',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; value: 0,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; expression: '0',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; isInteger: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'numberValue',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: '5mxSEl+E6b6DnP4/'</strike> } },<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { type: 147,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>typeName: 'BTMParameterQuantity',</strike><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { units: '',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; value: 0,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; expression: '0',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; isInteger: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'anyValue',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; nodeId: 'gHBfTGWBv2ekydiC' } },<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { type: 147,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>typeName: 'BTMParameterQuantity'</strike>,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; message:<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; { units: '',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; value: 0,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; expression: '20 mm',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; isInteger: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; parameterId: 'value',<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: 'MIPxQRFxB9slK+pV'</strike> } } ],<br>&nbsp;&nbsp;&nbsp;&nbsp; suppressed: false,<br>&nbsp;&nbsp;&nbsp;&nbsp; namespace: '',<br>&nbsp;&nbsp;&nbsp;&nbsp; subFeatures: [],<br>&nbsp;&nbsp;&nbsp;&nbsp; returnAfterSubfeatures: false,<br>&nbsp;&nbsp;&nbsp;&nbsp; suppressionState: { type: 0 },<br>&nbsp;&nbsp;&nbsp;&nbsp; hasUserCode: false,<br>&nbsp;&nbsp;&nbsp;&nbsp; <strike>nodeId: 'MhQQaUQzEjzS4GyOn'</strike> } }<br></div><div><br></div><div></div>
Function for POST request
<div><br></div><br><div><div>const&nbsp;addFeature&nbsp;=&nbsp;(documentId,&nbsp;wvm,&nbsp;wvmId,&nbsp;elementId,&nbsp;feature,conf,&nbsp;cb)&nbsp;=>&nbsp;{</div><div>&nbsp;&nbsp;var&nbsp;opts&nbsp;=&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;d:&nbsp;documentId,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;e:&nbsp;elementId,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;resource:&nbsp;'partstudios',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;subresource:&nbsp;'features',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;feature,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;sourceMicroversion:&nbsp;conf.sourceMicroversion,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;serializationVersion:&nbsp;conf.serializationVersion</div><div>&nbsp;&nbsp;};</div><div>&nbsp;&nbsp;opts[wvm]&nbsp;=&nbsp;wvmId;</div><div>&nbsp;&nbsp;onshape.post(opts,&nbsp;cb);</div><div>}</div></div>
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
    Here is an example post body to create a variable of:
     Type: Length
     value: 1.01*in
      "feature": {
        "type": 134,
        "typeName": "BTMFeature",
        "message": {
          "featureType": "assignVariable",
          "name": "",
          "parameters": [
              "type": 145,
              "typeName": "BTMParameterEnum",
              "message": {
                "enumName": "VariableType",
                "value": "LENGTH",
                "parameterId": "variableType"
              "type": 149,
              "typeName": "BTMParameterString",
              "message": {
                "value": "xyz",
                "parameterId": "name"
              "type": 147,
              "typeName": "BTMParameterQuantity",
              "message": {
                "expression": "1.01*in",
                "parameterId": "lengthValue"
              "type": 147,
              "message": {
                "expression": "0*deg",
                "parameterId": "angleValue"
              "type": 147,
              "message": {
                "expression": "0",
                "parameterId": "numberValue"
              "type": 147,
              "message": {
                "expression": "0",
                "parameterId": "anyValue"
              "type": 147,
              "message": {
                "parameterId": "value"
    type corresponds to the parameter type (which is in plain text typeName).
    We've been working on improved ways of documenting (and generating) features through the API.  But currently I think the best way to get it is via a GET on the featurelist to get a representative feature and fill in the blanks.
    Jake Ramsley
  • maximilian_hansmaximilian_hans Member Posts: 3
    edited October 2019
    Thanks for the quick reply, Jake!
    Unfortunately I still can't get it to work. I assume that I still need document und element Ids and such stuff in my request body, right?
    I added your code to my request body but still get a 400
    here is the body I am sending through:
    <div>const&nbsp;request&nbsp;=&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;d:&nbsp;'4f829ead28e0bf7baee955f9',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;e:&nbsp;'171cae564629ef5c97accf82',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;resource:&nbsp;'partstudios',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;subresource:&nbsp;'features',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;w:&nbsp;'e3f2c04ea2b4000581289810',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;feature:</div><div>&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;134,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMFeature',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;featureType:&nbsp;'assignVariable',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;name:&nbsp;'',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;parameters:</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;[{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;145,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterEnum',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;enumName:&nbsp;'VariableType',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;value:&nbsp;'LENGTH',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;parameterId:&nbsp;'variableType'</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;},</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;149,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterString',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:&nbsp;{&nbsp;value:&nbsp;'xyz',&nbsp;parameterId:&nbsp;'name'&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;},</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;147,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterQuantity',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:&nbsp;{&nbsp;expression:&nbsp;'1.01*in',&nbsp;parameterId:&nbsp;'lengthValue'&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;},</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;147,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterQuantity',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:&nbsp;{&nbsp;expression:&nbsp;'0*deg',&nbsp;parameterId:&nbsp;'angleValue'&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;},</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;147,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterQuantity',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:&nbsp;{&nbsp;expression:&nbsp;'0',&nbsp;parameterId:&nbsp;'numberValue'&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;},</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;147,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterQuantity',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:&nbsp;{&nbsp;expression:&nbsp;'0',&nbsp;parameterId:&nbsp;'anyValue'&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;},</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;type:&nbsp;147,</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;typeName:&nbsp;'BTMParameterQuantity',</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;message:&nbsp;{&nbsp;expression:&nbsp;'1.01*in',&nbsp;parameterId:&nbsp;'value'&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}]</div><div>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}</div><div>&nbsp;&nbsp;&nbsp;&nbsp;}</div><div>}</div>
    This is the method, endpoint, headers, and body that I used.  The doc ID, workspace ID, and Element ID should be in the URL, not the body (which I am assuming the request will fill in).
    ===== Onshape REST Request: POST https://cad.onshape.com/api/partstudios/d/32bdf212296deb7cbae78114/w/c8a1e1a3dce1ae7a15bbd034/e/2a44947bf4d2c0925ce25332/features @ 2019-10-27T23:40:26.222Z
    > User-Agent: NodeJS-Rest-Client/1.104
    > On-Nonce: TFeg3D7...truncated...owQT
    > Date: undefined
    > Cookie: on=wKCk...truncated...X2szdfQ=
    > Cookie: XSRF-TOKEN=iLF...truncated...w==
      "feature": {
        "type": 134,
        "message": {
          "name": "",
          "parameters": [
              "type": 145,
              "message": {
                "value": "LENGTH",
              "type": 149,
              "message": {
                "value": "xyz",
              "type": 147,
              "message": {
              "type": 147,
              "message": {
              "type": 147,
              "message": {
                "expression": "0",
              "type": 147,
              "message": {
                "expression": "0",
              "type": 147,
              "message": {
    Jake Ramsley
    I will have to look into that in more detail later, but it works when I put it into a 'body' object. thanks you for the quick help!
