Issue with GLTF translation (on assembly)
Hi,
We have an issue with the translation API using the GLTF format. We are getting the error below from the API explorer. Note that all other format successfully completes using the same parameters.
“requestState” : “FAILED”,
“requestElementId” : “a33dd01ffe6a3cdb17fc581d”,
“resultExternalDataIds” : null,
“versionId” : null,
“documentId” : “d0b49c63fd0bc7220a9a9de8",
“workspaceId” : “0ef27cd69489fcbdcfea6d7a”,
“resultElementIds” : null,
“resultDocumentId” : “d0b49c63fd0bc7220a9a9de8”,
“failureReason” : “<a class=os-import-filename href=‘Assembly 1’>{1}</a> was not exported. Invalid GLTF detail parameters were specified.“,
“resultWorkspaceId” : “0ef27cd69489fcbdcfea6d7a”,
“href” : “https://opal.onshape.com/api/translations/5dd463902eb254149e3ff1a8“,
“id” : “5dd463902eb254149e3ff1a8",
“name” : “Assembly 1"
“versionId” : null,
This looks like a bug on our end. I'm investigating it and I'll let you know what I find.
Cheers,
-Ethan
The interface is apparently using the Document translation API instead (don't know if it's documented), export works fine if you pass the correct parameters:
"elementId": {assembly_id},
"formatName": 'GLTF',
"flattenAssemblies": False,
"yAxisIsUp": False,
"triggerAutoDownload": False,
"storeInDocument": False,
"grouping": True,
"configuration": {encoded_config},
"resolution": "coarse",
"distanceTolerance": 0.00024,
"angularTolerance": 0.2181661564992912,
"maximumChordLength": 10,
Where did you find those parameters to pass to the API?
