Split a double helical gear
Math
Member Posts: 9 ✭
Hello,
I have generate a double helical gear using the spur gear feature.
Il would like to split it into multiple part (in order to print it with my 3D printer).
I would like to split it between the folling 2 faces as illustrated below :
The faces have the same angle than the helical teeth and are positionned between 2 teeth (in the midle).
With 2 faces like this, the split function doen't work.
But I have no idea how to do this ?
Could someone have an idea ?
Link to the document : https://cad.onshape.com/documents/d7d11eab906133198d413555/w/083f79d6fbb0d9cf4686f5bf/e/7ecd1d5cfca2478e899a78cb
Thank
Math
HWM-Water Ltd
HWM-Water Ltd
