Error when calling transformedInstances api endpoint
I get this message: {'moreInfoUrl': '', 'message': 'Invalid JSON input.', 'status': 400, 'code': 0} when calling transformedInstances api endpoint.
My post body looks like:
I used json.dumps to convert the dict to json and instances work work fine with /assemblies/d/:did/w/:wid/e/:eid/instances end point. So, I don't know what can go wrong to fail this api call...
any suggestions?
"transformGroups" : [
"transform" : [],
"instances": [{xxxx}]
<br>I used json.dumps to convert the dict to json and instances work work fine with /assemblies/d/:did/w/:wid/e/:eid/instances end point. So, I don't know what can go wrong to fail this api call...
any suggestions?
1
