How to change the size of circle diameter
In tutorial  video 2 there is a menu item to change the dimension.
in new version there is no such an option.
How to change the sizes of the fugures?
    Is the sketch active? If the sketch geometry is grey (inactive) then double-click the sketch from the feature list (not from the screen) or right-click the sketch on the screen and click edit.
  • rustam_mizov
    rustam_mizov Member Posts: 7 ✭
    where to click to change the diameter. this is a mobile app
    That makes a big difference...   with the sketch selected (like you have in the image) tap on the screen with 2 fingers and select edit.
  • rustam_mizov
    It does not solve issie since I could NOT find the "Dimension " menu item. If you coukd at the screen attached in the previous version it was a specual menu item. Now it has gone.
    You have the latest version of the app? Can you post a screenshot of what you are (not) seeing?
  • rustam_mizov
    It does not solve issie since I could NOT find the "Dimension " menu item. this video is what I am seeing.
    https://cloud.mail.ru/public/7r4w/mjANAH1bQ
    That menu of icons is scrollable - the dimension icon is below the slot icon
  • jack_hoover
    jack_hoover Member Posts: 2 ✭
    Could not find a way to give any values for circle.  I followed those instructions but apparently I dont have "edit" option.
  • neil_brennan
    neil_brennan Member Posts: 5 ✭
    Basic editing in Onshape is incredibly frustrating and seems to work in different erratic ways depending entirely on developer whim. I tried setting a dimension on my circle (as suggested above) only to get an error message saying you can't set a dimension on the point in a circle. Then I had to "escape" the dimension to do anything else. I tried double-clicking in as many different parts of the circle as possible, none of which worked. Then I tried single-clicks and occasionally something useful looked like it flashed on screen. I can only imagine the number of miserable people who just try this and give up.
  • pavel_kislitsyn
    pavel_kislitsyn Member Posts: 2 ✭
    you need to define a dimension for it in the sketch - then you'll be able to click on it and edit the value. if you select a circle with no dia dimension defined, it'll show you the original dia you dragged it out to when you created the new circle and you'll see if in the bottom right callout, but you won't be able to change it.
  • mebo12453
    mebo12453 Member Posts: 3 EDU
    I think you can select dimensions, then click on the object. You'll get an arrow thing and choose which dimension you want to change. Then you can enter a number for it.
  • carmatic_frua
    carmatic_frua Member Posts: 4 ✭
