If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
How to create a perpendicular sketch
 pavel_janeček953
                    Member Posts: 13 ✭
pavel_janeček953
                    Member Posts: 13 ✭
                    Greetings to you all. I'm a beginner and my English is very weak. I need advice. How to create this model in the attachment. These are mainly vertical holes in the model, perhaps I can handle the rest. It can be a whole circle, it does not have to be a semicircle. It is a tungsten electrode grinder for welding. Thank you very much for your advice. https://www.thingiverse.com/thing:2944235
                1
for holes, create an additional plane for the sketch and make by turning
look at this
https://cad.onshape.com/documents/9665e3aaf22c9b1d917be5f6/w/266292964089eb13b1c6af4a/e/bea66ba927075df4c661b2cf
Nice work @Józef_D
@pavel_janeček953
https://cad.onshape.com/documents/5431ce5736f06d159feab4d4/w/bca8e518be7d34b82fe40ba4/e/cb4eefe85ae14fffdef96f86
Here is a great FeatureScript made by Konstantine Shiriazdanov
MultiMateConnector
At times, It can save a few steps when setting up a plane
You use the MultiMateConnector FeatureScript to make a copy of a mate connector. Also, you have fields in the featurecript that allow you to move that copy to wherever you want in 3-D space and place the mate connector at whatever angle you want to in 3-D space.
That copy of the mate connector, which has been moved and rotated, can be used in place of a plane when doing a sketch
