Hole Tool Configuration
dt_userdt_user Member Posts: 8 PRO
I have not dug into the feature script yet to see if this is possible, but is there any chance the hole tool annotations (ie "drill size") will be made available for configuration?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,245 image
    Yes, but it will take a while.  The hole is actually driven by the numeric parameters and the connection from standards to these parameters is done via editing logic.  That's why configuring the standards wouldn't work.  We're doing a little early work on a redesign, but it's a major project.
  • Kyler_WalkerKyler_Walker Member Posts: 207 PRO
    I also would like to configure my holes.
  • Alex_KempenAlex_Kempen Member Posts: 255 EDU
    Kevin_O_Toole did make a tag holes feature somewhat recently - you can use it to tag holes with custom hole annotations.
