Need coordinate system (xAxis, zAxis) help for a transform
Marc_Miller
Marc_Miller Member Posts: 111 ✭✭✭
I'm trying to learn some Featurescript but am having trouble getting the xAxis and zAxis  vectors for a transform.
My Featurescript UI has the user select a start point (vertex), and a direction.  From that I'm trying to move the orange strip (that was created by FS and is located at the origin) to the user selected point, and also orient it to the picked direction.
Here's my test file.   I tried to get values for xAxis and zAxis on lines 42 and 43, but that doesn't seem to evaluate to anything (returns "undefined").
So I'm not sure how to get that, or what I need to put in Line 71 for xAxis and zAxis.
https://cad.onshape.com/documents/fa7433af79b5a1cd34725002/w/7fe2195f698aeb2a16d39728/e/fdcb389696130b3c594eba09
Thank you for having a look.
  • lana
    evAxis returns line:
    const axis = evAxis(..);
    const origin = axis.origin;
    const direction = axis.direction;
    Should work.
  • Marc_Miller
    Thank you @Jake_Rosenfeld
    I got it to work after correcting those filter and eval lines, and adjusting my moveFrom coordinate vectors.
    More to experiment with now!
    Thank you @lana
    I might come back and try that out if I decided I don't want to use a mate connector.
  • Marc_Miller
    edited March 2020
    @Jake_Rosenfeld
     I experimented a bit more and decided that the simplest UI that is also really flexible about where to locate AND orient the object is simply a Mate connector option.  With the ability to locate, rotate, flip direction, re-orientate, and offset all right there, Mate connectors are awesome!
    I saved a version of the document here for anyone that may be searching the forums for this sort of example in the future.
    https://cad.onshape.com/documents/fa7433af79b5a1cd34725002/v/6611496955cb9476a069e904/e/b9759b088e6afd81fa3c039a
    It has two Featurescripts, the first with the Point and Mate connector option, and now a second one with just the MC option.
    Cheers
    -marc
  • owen_sparks
    Nicely done :+1:
    Owen S.
    HWM-Water Ltd
