duel extrusion
gideonwaldner
Member Posts: 32 EDU
can I create duel extrusion files on on-shape and if you can how?
gideon waldner
I'm sorry, I don't understand the question. What do you mean by dual extrusion files?0
If you mean 3D print on a duel extrusion head printer, then yes. You will have to split your part into the required shapes then export each resultant part.Senior Director, Technical Services, EMEA0
is there a tutorial on itNeilCooke said:If you mean 3D print on a duel extrusion head printer, then yes. You will have to split your part into the required shapes then export each resultant part.gideon waldner0 -
john_mcclary said:I'm sorry, I don't understand the question. What do you mean by dual extrusion files?It means they fight each other at dawn
O.S.
HWM-Water Ltd3 -
im thinking of getting a duel extruder 3rd printer and im woundring if i can export files to 3rd printjohn_mcclary said:I'm sorry, I don't understand the question. What do you mean by dual extrusion files?gideon waldner0 -
You can export to many different formats. STL is one you are probably looking for0
This coaster was designed in Onshape and exported as STL. After slicing I printed a number of them on a dual (not sword fighting @owen_sparks [1]) head printer.
https://cad.onshape.com/documents/24ebbb4af61fa4df9922bdc7/w/4c49a71723e8bf4c8446e57f/e/309093e0c22fd4eaaa5a8371
[1] It's a small island thing.0 -
what do you use to slice itbrian_jordan said:This coaster was designed in Onshape and exported as STL. After slicing I printed a number of them on a dual (not sword fighting @owen_sparks [1]) head printer.
[1] It's a small island thing.gideon waldner0 -
