Is any option to add tolerances (or notes) to the sketch dimension?
MS_021
Member Posts: 7 PRO
A dimension is not absolute and required to have tolerances.
You can add tolerances in drawings only.
The only way to add tolerance in a part studio sketch will be to add a comment in the dimension
such as:
2.0 in /* +/- .005 */
anything in between these two marks: /* */ will be ignored by the sketch solver.
Unfortunately they will not be parametric to a drawing...
And there is no way of seeing the comment until you attempt to edit the dimension (see above image)
This is what it looks like in drawings:
2 -
John,
Unfortunately this “NOTE” /*tolerances*/ will be visible only if you double-click on dimension and disappears when dimension is not active.
This time is wasted.
Thank you.
1 -
I did mention that in my original post. Sorry those are your options.
There are some improvement requests for this somewhere. You should add your vote1
