Join the Helpful Engineering Group to fight against Covid-19!
sebastian_glanzner
Member, Developers Posts: 474 PRO
There is a group of volunteers designing open-source medical devices to support the fight against Covid-19, and they need your help!
Here is the main page of the project, there you can find the link to their slack channel for discussion and ideas:
https://www.projectopenair.org/
https://www.helpfulengineering.org/
*** Project Open Air and Helpful Engineering split in different projects. I updated the link ***
Initially the group was founded to work on medical devices, such as open-source ventilators.
The problem with the fast growing number of patients is, that the hospitals will run out of medical ventilators very soon.
The goal is to provide a quick and easy solution that can be reproduced and assembled locally anywhere in the world.
In the moment there are more than 9000 volunteers working on multiple projects including engineering, programming, crowd-sourcing and more!
Start:
Here is a start document to answer initially questions about the project:https://docs.google.com/document/d/1cM87eJdXhP_8e9gJJZ_SnZXdo_huWsBmMzcqYWbhEOg/preview#
Volunteers:
If you have free time, please fill out the form to register as a volunteer:https://docs.google.com/forms/d/e/1FAIpQLScu-4OOB5dGLWoSIA33CkAH__LE6b_M2PKRh0z6PMavL39uUQ/viewform
Fabrication Equipment:
If you have 3D-printers, CNC-machines or other production facilities that you can provide, please fill out this form:https://docs.google.com/forms/d/e/1FAIpQLSfCzXLp4cvlgBFh1OR81-Kek6SAGnNC8jJQcHyBUJbPSIvXgA/viewform
Onshape would be ideal to design such devices with people from all over the world!
Thank you and stay safe
https://cad.onshape.com/documents/a5d67baebef4534615731db1/w/8f5a8b35130cb7578c857eaf/e/545c7c394a7fdff97cfcf3af
Did you design that on your own?
How does it work? Are you programming a controller to drive the stepper motor?
How do you prevent the piston turning with the threaded rod?
If you join the group you can present your idea and I'm sure you will find others to collaborate
Thanks for sharing
Sorry I answered late sebastian_glanzner
- My English is very poor and I am concerned that a prototype can harm a COVID-19 patient.
