How to fill in the two surfaces
tucker_epp
Member Posts: 1 PRO
How can I fill in these two surfaces while leaving the center open? I have tried the fill option and I also tried making the curves using the composite curve tool, but it still won't fill in.
Here is a picture of the part: (sorry its a link because Onshape couldn't upload the image for some reason)
https://imgur.com/CGyOgNH
Try LOFT set to SOLID
if that doesn’t work
try LOFT set to SURFACE
