Can I relate a dimension to another?
Example:
the vertical side of a rectangle must be the half of the horizontal so that when I change the horizontal dimension the vertical one will change automatically
Thanks for your support
  • bruce_williams
    Check out variables
    www.accuratepattern.com
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    For simple divisions like half. you can just use geometry instead of a variable.
    here you see i created a construction line, made it equal the short edge, then constrained the end point to the mid point of the long edge.
  • bruce_williams
    Check out variables
  • john_mcclary
  • francesco_longoni
    francesco_longoni Member Posts: 3
    thanks
    I will use your suggestion for this simple action.
    In my case I prefer to use variables, I probably made the wrong example to simplify my question.
    Thank a lot for the support.
